Thread: MM5700 in T4
AAngel
03.14.2007, 12:49 AM
The only parts that I was continually breaking was the arms. I built my T4 out for parking lot racing and for nothing else. It was completely setup to go as fast as possible. The truck itself is as good as it gets, IMO; but when you go that fast on concrete things just break. It wasn't unusual to see my T4 sliding the scale quarter mile on its roof. The transmission in the T4 is bullet proof, with one caveat. You HAVE to do maintenance. I ran my T4 for a month without pulling the tranny and all I found inside was two cracked up friction rings and black dust where the diff balls used to be. It really didn't mess anything up, I just needed to rebuild the diff. If you are having tranny problems, then the T4 will be the ticket.
The only other advise I can offer, if going fast is the name of the game, is to stay away from aluminum arms and shock towers. They just get bent and are more expensive to replace. The same goes for body posts. You might want to consider an aluminum tranny case. I occassionally had problems with stripping the screw holes in the plastic case. If you don't go aluminum, get into the habit of tapping the screw holes, rather than forming the threads in the plastic with the screw. This really helps if you tear your truck down often. I believe the tap size is 4-40. If you go with the FT version of the T4, when you do break the arms, just replace them with the standard plastic arms (goes for shock towers too). In the alternative, you could boil the FT parts, this will make them a bit more flexible and will probably hold up a bit better with impacts.
As far as the breaking parts goes, you really have to take what I say with a grain of salt. For me, RC is a release. When I play, I really play. I'm very hard on my equipment. If you keep it sane, chances are that you won't be replacing parts nearly as often as I was; and with the T4, the tranny won't be an issue.
