glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.14.2007, 10:34 AM
I would recomend an 8XL for running on 4s 8000 and MM.
As for layout, sounds like you want something like BrianG's Hyper 8. My 8ight has the motor on one side, battery on the other.
My 777 has the motor over the center diff like that, but I did custom driveshafts and moved the diff forward so the batteries could tuck in behind the center diff. Brian' sis similar but leaves thd diff centered in the car and the batteries are a little farther out from the center.
I really like the 777 layout but it does require custom shafts... more work to do. Some pics of my cars....
http://www.rc-monster.com/forum/showthread.php?t=5572
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
