glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.14.2007, 08:26 PM
I'm not one of hte emaxx guys here.... others are more in tune to exactly what you should upgrade.
For batteries I would say a pair of 8000mah packs would be good... and will give you the big run time you want... should do 30+ minutes of solid runtime.
The emaxx is well suited to higher kv motors. The 9XL would be perfect for you in a center diff style truck, but you might not be able to get the gearing tall enough in a emaxx with a stock gearbox/motor plate.
See what others recomend...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
