03.17.2007, 12:50 AM
Sounds very odd... I would look very close at all connections/solder joints and try taping all the wires in place so they can't bump around and see if that makes any difference.
Try using a capactior on the reciever, like the $6 Spektrum one.... just in case it's the rx seeing a voltage drop.
Can you tell if it's a total loss of power, or just a "bogging"?
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
