gixxer
gixxer's Avatar
03.19.2007, 04:28 AM
Originally Posted by AAngel
My charging setup right now is a Thunder Power 1010C charger with a Thunder Power balancer. What is nice about this is that the balancer can communicate with the charger and work in tandem, rather than independent of each other. The LBA10 will work in this way with the Hyperion Charger as well.
I have a 989 and I just picked up a hyperion 1210i because I liked how the balancer worked with it. I really like that now I can see exactly what each cells voltage is while its charging. no more looking at blinking lights for me.
as for the 989 its a good charger and should be more then enough if you are just getting into lipos. it comes with the power supply and will charge up to 10amps all for around $140.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
