ok, so i read up on some truggyracer threads last night, and made a list of what i'll need..
17mm-
pins -
http://www.amainhobbies.com/product_...oducts_id/2742
hex -
http://www.amainhobbies.com/product_...oducts_id/2717
cvd kit -
http://www.amainhobbies.com/product_...oducts_id/5928
cvd -
http://www.amainhobbies.com/product_...oducts_id/5925
stubs x2 -
http://www.amainhobbies.com/product_...oducts_id/5519
buggy arms-
hubs -
http://www.amainhobbies.com/product_...oducts_id/2692
towers -
http://www.rc-edit.com/piw.php?partN...kit=17&lang=en
upper arms -
http://www.amainhobbies.com/product_...oducts_id/2685
3 degree plate -
http://www.amainhobbies.com/product_...oducts_id/3215
ackerman -
http://www.amainhobbies.com/product_...oducts_id/3227
bellcranks -
knuckles -
http://www.amainhobbies.com/product_...oducts_id/3219
I'm not sure if that's the right 3 degree plate to use.. couldn't find an exact answer, only that it's 3 degrees.
also, the buggy arm conversion that i think I'll try uses RC-Edit towers, as they have an additional hole, that's used to hold the buggy arm's hinge pin. is there another setup, that you'd recomend that I could use the stock towers?
do you guys have a parts list for the CRT conversion? what else am I missing? I'd like to do as little "hacking" as possible on the front end.
and also, I'm not sure where to get RC-Edit parts from, as there's no US dealer listed.
and, the KWM axles are recomended instead of the Sportwerks axles.. that part doesn't show on KWM's site, so i'm guessing ebay's probably my best bet at finding a set? not meaning to hijack, just interested in what the lsp can be turned into.
btw, I've got MT3 rims that are made for the ofna dominator. I'm assuming that those are the same offset as the Jammin's?
skellyo, do you have a link to "mugen steering links"?
