gixxer
gixxer's Avatar
03.23.2007, 12:49 AM
crayjr, just wondering does your mm give you any issue with the 5s when the battery is fully charged? reason I ask is mine cuts out when I give it throttle if the pack is fully charged. If I just hold the car in the air and give it full throttle for 20-30sec then everything seems to work fine. As if the 21volts is to much but if it drops a few 1/10th's everything is fine.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
