Originally Posted by gixxer
crayjr, just wondering does your mm give you any issue with the 5s when the battery is fully charged? reason I ask is mine cuts out when I give it throttle if the pack is fully charged. If I just hold the car in the air and give it full throttle for 20-30sec then everything seems to work fine. As if the 21volts is to much but if it drops a few 1/10th's everything is fine.
I have not seen anything but according to my nomadio it shows 20.89 on a fresh pack
BP you must run a really stiff setup because my current combo's are stronger than my 4400 and they can't do it
