glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.25.2007, 05:04 PM
I used to run a Hacker C50 and MasterCar Sport. They had two versions... one with built in BEC and one without (OPTO).
Either way, it's best to not use the built in esc. It's not quite as simple as cutting off the switch. Do this... remove the red wire from the reciever plug. This disables any built-in BEC.
Then use a rx pack or other BEC device, powered off the main battery, to power the rx.
You can use the esc swtich if you want... or you can cut it off and solder the wires together (permanently turned on). Also you can use another switch on the separate BEC device to switch on the rx... or you can leave it hardwired also.
Without switches you simply unplug the main battery.
It's a universal issue... not specific to the Hacker escs.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
