03.25.2007, 05:08 PM
You say the switch does nothing.... but it should power on/off the esc. Perhaps there is a broken wire/connection somewhere. That would explain the esc not working and the switch doing nothing. Try cutting the switch off and twisting/soldering the wires together.
It's been a long time since I ran my Hacker. I forget the programming/use procedures....
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
