Originally Posted by furu
I've considered the MM. I believe that a true 1/8 controller like the Quark or MGM 160 is better than the MM. A MM + Neu combo could obviously be an option. I'd need a UBEC with the MM, but wouldn't the MGM be fine without one?
There are just too many ways you do this. To many combos of esc+motor. And too many opinions :confused:
Expect issues with the Neu and MM setup. There are quite a few reports of bad cogging with this combo. The MM apparently does not like Neu motors yet. There was a rumor of a software fix, but I think CC is too busy on the MMM to devote time to tweaking software to support a motor the ESC is not technically supposed to support anyway.
