03.25.2007, 10:56 PM
Originally Posted by jhautz
Then Id say the buggy diffs would be better. Staying closer to the stock gearing that way. The truggy diffs would lower the overall gear ratio quite a bit. Youd need to go up in pinion teeth quite a bit to compensate.
Than you sir.
