glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.26.2007, 12:07 PM
Here's a clip from another forum:
Ok, I got a dumb question. I worked on going through the manual setting mode, which wasn't too bad, but it seemed to end early. Trying to set the speed to not have reverse at all, and I wanted to know if you select this option, is step 3, Reverse Amount, no long gone through?
Also, when I get to the end of all the settings, I get a single repeating beep. Is this the last mode or is it something else? Nothing in the manual describes this.
I tried it again, and basically it does go through all the steps. I hooked it up to my pc and confirmed all the settings.
I sent this to support:
> 1. I am attempting to manually configure my mamba max system, and the
> last setting only gives single beeps instead of the multi beeps based
> on what part you are on. Is this correct?
> 2. If I select a drive configuration without any reverse, do I still
> need to go through the reverse power selection part?
RESPONSE:
#1 That's an error, we're fixing it. It's still setting the correct
motor type, etc. It's just beeping once instead of 9 times.
#2 You would still have to even though it wouldn't effect anything.
So it appears that it's programming vorrectly... but the end-program beeps are messed up....
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
