AAngel
03.27.2007, 03:41 AM
gixxer, I was using the big 6mm connectors from Neu, but with all of the trouble I've been having, I said screw it and direct soldered all of my connections. I've found that catching a cold joint like those is pretty easy and it's just one less thing to worry about.
GD, if that is the only cogging issue you're having, I might just go ahead and order a Neu motor for my truggy. Maybe having a more efficient motor with more nuts will run better. I'm thinking 1515/2.5D for more torque. I really wish that I have a 9XL laying around so that I can try that out to see what effect a lower turn motor geared up would have.
Oh...I can't wait until the day that I have everything settled and I know that I won't have any surprises.
I was very hesitant to pull the trigger on the Quark. I know that Mike had good things to say about the Quark/Neu combo, but the thermal path worries me. The manual scared me a bit too. LOL. I also checked out the MGM controllers and the ones that I can justify spending money on really don't impress me with their specs. Maybe I should just quite all of this whining and get myself a Neu motor. At least I'll have it, even if it doesn't play nicely with my MM controller. It will give me something to look forward to in the Monster Max.
