skellyo
skellyo's Avatar
03.28.2007, 12:31 PM
Originally Posted by My_stampede
My esc fried and took the motor with it or vice versa.. i called castle and they handled it perfectly. i installed my new mamba in the truck and went off about 10minutes into my first run it thermaled.. motor temps were 139 battery at 120 and esc at 195 by the time i had body off and temp gun ready. this is stampede. its the 7700 motor but i dont understand the issues. i even have a window cut out like a nitro car. wether the gearing is 13/90 or 17/90 the esc temps are the same. all the gearing does is seem to change motor temp. im at low start power lowest timing and no drag brake with 40% punch control. im using 7 cell ib4200wc's.
With no body on it the temps are normal
The ESC is mounted on the rear shock tower.
The big issue is that the 7700 motor was not designed for use in a truck like the Stampede. The ESC temp being that much higher than the motor means you are severely overgeared. You probably won't be able to get it geared properly for that vehicle unless you drop the tire size way down. I'd really suggest looking into a different motor to get the temps down. Also, just because you go with a lower kv motor, doesn't mean you can't go fast. There are at least 2 of us on the forum with 10th scale trucks running motors under 5000kv that are doing 45+ mph on 2S lipos.
