elegal
03.29.2007, 09:34 AM
You are mounting your motor towards the front, correct? I have mine towards the right rear, with the batteries on the left rear, and the truck is rear-biased a bit. Do you have any suggestions for differential oil weights or tire type? I am running the stock tires and 7000/50000/5000 oil in the diffs F/C/R. Thick stuff in the center diff helps the front tires not turn into pizzas under acceleration.:018:
