Another Brushless CRT
architorture
Thumbs up Another Brushless CRT - 03.31.2007, 01:08 AM
First off, I'd like to thank the people of the forum for all of their knowledge.
I finished my brushless conversion of a Jammin CRT X-1. I am really pleased how it turned out. I dont see how someone would want to still run nitro after driving this truck.
I have only run it twice for about 5 minutes each, due to rain, but I am impressed with the speed, handling, and braking. I was worried that I would be dissapointed with the 8XL performance due to everyone talking so highly of the Neu & Lehner's, but it is fast enough until the Mamba Monster Max comes out, when I will try 6s if it is supported!:018:
Like I said, I have only run it for short periods of time, but the temps seem to be ok. The ESC is a little warmer than I would like, so I am planning on getting a fan, but the motor and batteries are only warm to the touch on 12/46 gearing.
I dont know what runtimes are yet, but based on the runs I did and what the batteries took back, I should be able to get a solid 20 minutes of hard driving.
The motor mount is from Mike, here at rc-monster. It is really heavy duty, however I needed to dremel the area where the shaft passes through in order to fit my pinion. This was one of the first CRT mounts. (I spoke with Mike and he is making adjustments to the future mounts) I like the fact that the mount replaces the stock front diff mount. The center diff bearing fits in there perfectly.
I used the following components:
Mamba Max ESC (disabled BEC)
Feigao 8XL motor
Custom battery boxes
RC-monster heatsink & motor mount
2x 4s 4000 maxamps packs in parallel
Kyosho 46t Nylon Spur with center diff flipped
6V BEC
Here is a link to my picture page: http://picasaweb.google.com/joeharri...rushlessCRTPro
Let me know what you think and if there is anything that I overlooked.
