glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.31.2007, 11:04 AM
You should use the lion setting cause it "peaks" at 4.1v per cell which woudl be better in case you don't stop it manually.
I think ou only need to set the # of cells... and charge current.
A couple things you can do with the settings....
1. when the pack is dumped all the way, you could try setting the max charge capacity to 100% or a little under that, to get it to cutoff the the charge before it gets to the 4+volts that the lion/lipo profile is looking for. This won't be an exact thing, but you might be able to get it close by playing with this setting.
2. you could set the capacity of the pack higher (like 4600mah) so the charger will allow a higher charge rate. The A123s can take it so why not? If you charge at 2-3c then it won't take long... so you could hang around to monitor it and stop the charge when you want.
If you do bump up the capacity like that, make sure you compensate for it by reducing the max charge capacity. Fro example... 45-50% if you set it to 4600mah(2x) .... about 30% if you set it at 6900mah (3x)
This way you can fast charge it but still have a failsafe of sorts...
For lithiums, there isn't a peak sensitivity...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
