03.31.2007, 07:25 PM
hmmm... how low is the dumped 2s pack? Must be under 6 volts... I didn't know if would be (stay) under the ICE's 'smartness'... I'm not sure what the minimum voltage is for the ICE to start a charge.
If this is going ot happen all the time, then it would be best to just buy a lipodapter...
For now you can put the pack on nimh charge for a minute to bump the volts up.. then switch to the lipo setting as planned. That should get it to work.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
