04.03.2007, 04:23 AM
the novak setups he is running for the b4 and t4 are 27t and 19t equivalent. You wont be pulling that many amps since they are very mild setups. Any of the packs mentioned would be fine. I would check with the track first to see if they are limiting you to a certain mah or anything since they are controlling the esc and motors you can use.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
