Originally Posted by skellyo
Hmm, is this loaded then? I could have swore it was rated @ 5800, tho I bought it quite a while back, so maybe I'm misrecalling it...
Regardless, the above setup is def off. The
Esc is rated for 3S lipo/ 12 cells, but the actual motor max depends on its kv (rpms/V) rating. The 5700 is ...5700 rpms/V. 12 cells is 14.4V, so that is well above the 65K rpm limit of the mamba motors. If you want to run that many cells you buy a lower kv motor like the 4600.)
