Thread: e-revo?
04.03.2007, 12:49 PM
The only problem I've had so far is that one of the pins broke that holds the output gear on the shaft. It's not as strong as they slipperential, but I like the fact that it is enclosed (including the CD if installed), provides some gearing reduction, and can have a two speed system.
I've never used it as a 2 speed so I can't help you there (wanted reverse and didn't want to use a servo for braking). Personally, I'd be a little concerned because second gear is engaged by a single clutch arm on a little pin embedded into the second gear.
