zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.03.2007, 10:42 PM
Originally Posted by BrianG
Awww man, that's not lapping! You should be able to see your reflection like it was a mirror when you're done! ;) That's one big heatsink! You gonna mount the front and rear suspension directly to it? ;)
LOL, i was planning on using it as a bulkhead!
I know, i know, not the best lap job i've done, but that's the best that 600 grit will get you! PLus, the grinder scares could not be removed.
The Quark sits very flat on it now, in fact, if I put a drop of water on it and put it on glass, it takes quite a bit of force to remove it. Which is a good sign of flatness, and smoothness. All I have to do now is get a copper pad (what was it 3mm?) for inside the Quark.
OH, and the 'La Mans" association called, and they said I'm qualified for the 24 enduro races! :005:
