04.04.2007, 10:17 AM
Thanks neweuser. My wishlist now contains the following
Warrior 9920 Brushless Car Controller
Feigao 540C XL Brushless Motors- 8XL
External BEC/UBEC
Strobe Slipper Kit w/Bearings
Nylon 51 tooth spur gear - Ofna
pinion size - mod1 -5mm: - 16 tooth carbon steel
pinion size - mod1 -5mm: - 18 tooth
Hardened steel idler gear-Emaxx transmission
I'm going to email Mike about a 15 tooth pinion and also the locker for second gear.
One other question i had was about running times. What will the difference be for the following combinations? 8XL with 14 - 16 cells and 7XL with 12 - 14
Otherwise hows it looking ?
