04.04.2007, 11:42 AM
I agree with Serum. It can take a while.
To test, I hold the outdrives in each hand an turn in opposite directions to "work" the inner gears. There should be no binding at all. Also, I push in and pull out on the outdrive cups (they'll still shift an itty bit) and make sure they shift less than 1/2 a mm, yet they still don't bind - but I can still "feel" the gears moving inside in both cases.
