zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.04.2007, 09:46 PM
Originally Posted by skellyo
The FLM chassis includes an extended CVD for the rear. You can use a regular MIP center CVD in the front.
Thanks.
Also, one of the drawbacks of the FLM is because i have to mount my A123 packs underneath, it will be the lowest part of the truck, probably ruining them. Plus the higher CG from batts, and higher motor, and the heaviest part of the chassis being up high.
This sucks, there is no chassis out there that is good enough/cheap enough. The G3 is my best bet, but it's just the extra $100 i'll spend, I'm running low right now as far as budget. Maybe i'll just wait until the snow is completely gone, and then purchase.
