Thread: So far so good
neweuser
neweuser's Avatar
04.05.2007, 10:22 AM
Originally Posted by ***RC***
Thanks for the info. Than the 989 is what I will probably go for. Do you balance the packs after every run, or every couple runs?
With the LBA10, you can balance as you charge. If you balance after a run, you will take a chance of going below voltage from my understanding, not sure if this is true, but I never do it after a run. I do mine after charging them.
