Erkan
04.05.2007, 03:35 PM
Ah ja, O.k.
the Controler iss a Hacker Master 90 Acro Comp !
usualy it is RC Aeroplan Controler, with a lot of compftable Features to program with a Prog. box !
it works pretty good, no Problems with starting slow or fast !
I don´t know, maybe the Breake might work also , it is prop. controlable but the Hacker Guys kant give me a garantie if the breakelektric will work in the Car conditions without getting damaged , so I decited to use the mechanik Break System first !
I think I will try to break just with the Controler, because i can losse some weight if this works ! And I´m a low Weight fan !!!
BRGS Stefan
