04.05.2007, 05:52 PM
the problem is where the wires exit the center-endcap of the packs. other than that, they would fit, but the screw-post started slicing thru the insulation (yikes!). so.....
what I've done for the time being is dremel cut the post level w/ the tray sides, round off that edge, cut 2 small pieces of vacuum tubing and sliced them lengthwise. I put the tubing on the tray lip on both sides of the post.
what that does is hold that end of the pack up just high enough and creates a gap for the wires. (both sides) (sorry I don't have a pic...)
Took a small velcro tie and run it thru one of the center batt slots and around the pack and outside edge of the chassis. that's working pretty well for now.
I was trying to do as little modifying as possible until I decide (or learn) the best set up. I already figure I'll end up dremeling out the post completely creating a notch in the tray end for the wires.
I've got 2 side-by-side packs on order and plan to get some 7-cell packs later, so I want to see how those are gonna fit before I cut any more.
btw- I'm REALLY digging' the truck, 'cept for the weak steering servo. that's next on the list.
