Originally Posted by xjbebop
oh wow...it's only $90!? I expected more.
so which end gets the new driveshaft? I assume that everything else (stock) bolts right up? does it come w/ hold down straps, or is everyone using the gorilla straps?
That chassis and some alum bulkheads and I'd be set for awhile, eh???
*does anyone have a naked pic of one assembled?
The back end gets the driveshaft. The stock front one works fine (or MIP, UE, etc.)
Most everything is a bolt on. No location for antenna or on/off switch. Aside from that all else bolts up well. Use a DuBro alloy antenna mount. Works like a charm. Use servo tape for the on/off switch and attach it to the side of the esc. Problems solved.
