04.06.2007, 08:01 PM
If there were horrible braking problems as this person suggested then it would be a big topic. He doesn't know what he is talking about... obviously he's just speculating.
As I have said before on this topic, I have no problems with "electric" brakes. It is different than "nitro" brakes and there are disadvantages, but it's not a big deal. You can't use the brake to help the car rotate like with mech front/rear bias brakes. But there is no spin-out problems... the only bad thing with motor brake is that the front tends to push when hard on the brakes.
So you may have to brake a bit earlier and roll the corner or be on power through the turn, compared to a nitro.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
