GriffinRU
04.06.2007, 10:13 PM
Originally Posted by GorillaMaxx360
so everything needed for it to work(basically just mike slipperential but a different motor mount) also the motor mount is machined right because in the picture it looks molded kind of
_also will it work with all size motors like the neu and feiago motors
Printscreen from CAD drawing, actual part - machined from aluminum.
Any 540-size motor with can diameter 35.8mm will fit. So, any Novak, Feigao 540 and smaller, LMT 19-series and smaller.
NeuMotors 15-series won't fit (with 18t pinion) because motors diameter 39.5mm.
I will check for possible motor and pinion combos later.
