glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.07.2007, 10:07 AM
This is too bad... looks like the Quark would be much better. It seems to work very well, without funky stuff like this.
btw, that 5s pack might just work with the MM too... but you might want to drop the motor kv a notch or two. 5s on 9XL should cure much of the problem you had before, if the MM won't blow a gasket on 5s.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
