GriffinRU
04.07.2007, 02:45 PM
Originally Posted by luvsrc
Thanks Griffin,Is hacker XL motors has a lesser torque or power than the NEU 1515 series?
You welcome,
By dimensions they should be very close to each other in terms of Power, but Neu being 4-pole motor has more torque at lower RPM by definition.
In addition Hacker rated their C50 XL-cans at 60A while Neu motors rated at higher currents, which means more torque again.
So, by all means same Kv motor from Neu will be 5-10% better then Hacker. Do not forget efficiency.
