04.07.2007, 07:45 PM
Well... the Revo slipper should be pretty good. I ran a Robinson slipper on my maxx.
The original emaxx slider shafts used to look like pretzels after running a high power brushless setup... but he HV should not do too much damage. I ran the old Hacker C50 setup (similar to a HV I would say) and the rear center shaf thas to be replaced with a steel CVD... and the rear axle sliders did twist quite a bit but still worked. (I actually swapped sides after they were permanantly twisted... and they worked good after that :) )
Use a mild setup like the Novak and keep the slipper working... and it should hold up imo. You might have to make the Pede diff a spool... fill it with JB Weld or something ;)
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
