AAngel
04.07.2007, 11:23 PM
I just had a good nap and am feeling better. LOL.
I put the MM/8XL running 12/46 gearing with the truggy tires. Instead of having start power turned all the way down, I turned it all the way up and reduced timing to lowest. Cogging is minimal and only sometimes.
Assuming that the Compro is a "better" controller than the MM, in terms of capability, I should be able to start with this gearing and tune for it. I'm going to go through all setting again. If I still can't get it to free wheel, it's going back, because that's the biggest issue for me. I can live without reverse, until I can afford a Quark, which is what I should have gotten in the first place.
Heatsinking the Quark isn't a problem for me since my esc rides on an aluminum pedestal which is bolted to the chassis, so in essense, my whole chassis is a heat sink. With a setup like this, I probably won't have heat problems.
