04.08.2007, 01:23 AM
Well, I did an eagletree test, and what I got was 42,000 rpm max, with a brief full throttle pull.
I can't remember the voltage the eagletree said, but either the volts the eagletree is reporting under load is wrong. OR, the rpm the eagletree is reporting is wrong. I am using the two wire RPM sensor.
Because that would require a voltage of 17.5 volts...... no way! The A123's under a little load will hover around 16 - 16.5 volts.
