04.08.2007, 08:41 PM
Typical squee, nicking the last one.... As for the x-brace issue, yeah, it is quite annoying that they didnt adress the bending issue. The obvious problem is that the motor mounting screws go up through the x-brace so they cant put a bar across that area to stiffen it up. The only solution I can think of are some kind of braces that run along parallel to the x-braces, either on the inside or outside if you see what I mean, along the whole length of the chassis, and are bolted down onto the battery plate. That way they wouldnt be in the way of anything, and would add much needed stiffness.....
