furu
04.09.2007, 07:32 AM
The problem with ballooning tires should be solved by using correct diff oil, shock oil and a good setup for the truck/buggy/car. Adding tape or mesh to a tire adds weight, and that's usually not what you want if you're racing.
If you just add tape the tires will still be up in the air spinning and not on the ground. Having lots of power doesn't help if you can't use it correctly.
