Patrick
Patrick's Avatar
04.10.2007, 05:35 AM
Originally Posted by overkill5000
what are you talking about i cant figure it out!im about to trim off my first gear is there something i need to know before following there instructions?
On the input shaft (the one with the two metal gears attached to it, it's also the one you have to cut for the single speed conversion and the one with thread on it) the gears are attached with a roll pin that goes through the shaft and through the gear, this roll pin can break. Just looking at it you can tell it isn't that strong, since it's hollow.
People put a drill bit or something else solid in the hole to replace the roll pin.
Obviously you only need to do it to the bigger gear since your going the single speed conversion.
