04.10.2007, 07:25 PM
Okay, it was fairly obvious really wasnt it. The plan is to mount a second steering servo in the other slot, and run that to a modified GPM bell crank (which will use the 2 servo-connect-to-bits). Add a Y-harness for perfect alignment (hopefully), and the two servos will push/pull the bell crank from both sides, giving double the turning power (revo style almost) at about 18KG of torque @ 6v. It should work wonderfully provided I get it all lined up/ centered okay (easy enough I hope), and it will look rather trick too. It beats paying $110 for a digital servo like a Hitec 5955TG- nice servo but $$$ -way too much for one servo. Unique is the key word I think for my plan, or barmy....
