AAngel
04.11.2007, 09:22 PM
You will need a bec with your esc, especially if you go with a MM. I always use a bec no matter what. It helps to keep your esc running cool. When you wire up the battery connectors in the esc with the deans, just add a connection for your bec so that it can draw power from the battery as well.
