04.11.2007, 09:43 PM
You usually connect it to both. If not, one battery pack will discharge slightly faster than the other since one is also powering the servos. Just hook the BEC wires to the ESC power wires (observing polarity of course) and you'll be all set.
Just make sure the UBEC input can take whatever battery voltage you are running.
Yes, it will work with any BEC-capable receiver (which most, if not all, are).
