glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.11.2007, 11:45 PM
I have taken apart a similar pack... smaller cells but with the PCB. THe PCB is only used as a way to connect the tabs nice and neat.
If I do it again I would use some flux and desolder braid or bulb... and try to suck the soldered tabs as clean as possible. Then it may not be too bad to get the PCB free of the pack.
Once it's apart, just build a pack like normal, without the pcb
I might just get bare cells next time... like I have with every other pack I've bought. Let me know if I can help
If anyone is thinking of buying some Kokams maybe you could sell them and get some bare cells... ;)
BTW, the new 30C cells are coming... the 4000s may already be available. They are priced just a little less than the 20C 4800 cells. (retail $70 ea vs $75 for the 4800) I'm hoping they will have a 5000ish size sometime
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
