AAngel
04.11.2007, 11:59 PM
crazy, from the pics I've seen of the V-Balancer harness, it appears that the little hole in the center is simply tapped into the joint between the two cells. Now that I think about it, I don't know how you'd adapt the Hyperion balancer. The Hyperion LBA10 uses the balancing harness to monitor the voltage of the cells and to discharge necessary cells to balance the pack, while the charging is actually taking place through the main discharge leads on the battery. It appears from the pics of the V-Balancer harness that the trakpower charging system actually charges through the balancing harness. I don't know. I may be wrong.
On the plus side, the V-balancer seems to be pretty inexpensive.
OK, I just said a whole lot of nothing. Does anyone know for sure?
