Originally Posted by chopndroptx
I have Flextek arms on my E-Maxx, but with Integy SHD bulks.
The Flextek arms are great, I didnt think they where when I first got them, due to the bushings being a little loose on the pins.:031: But it doesnt hurt anything. Then I started bending front lower pins on almost every run.:035: So I came up with a solution, and bought a pin brace and modified it to fit with the arms and avoiding the steering arms. Havent bent a pin since, just lost a e-clip or 2.:027:
All in all they are great arms once you get the bugs worked out. And FYI you can get them for $220 at rcplanet.com, but Im sure Mike might work with you on the price!
Here are some pics of the brace:
Thanks, I definitely appreciate the info...
I wonder if others had the same problem (bending pins) as you? Or if it is because of the Integy bulks?
