ssspconcepts
ssspconcepts's Avatar
04.14.2007, 12:50 AM
Originally Posted by zeropointbug
That's true that it will make it stronger, but how strong does it have to be?
What size allen key did you use? And drill bit size?
I started out by using a small nail....actually drove it down inside the existing hollow pin. It eventually failed. Then I spent the next couple of days disassembling my maxx tranny and doing it the right way. You ask how big does it (the pin) need to be....well there is definitely a balance-afterall you don't want to weaken the shaft.
I ended up using a 2mm hex key...but bear in mind that it did take a little bit of gentle grinding to get it to fit in the hole. I think I used a 5/64 drill bit.
