Eccentric
04.14.2007, 11:46 PM
Originally Posted by 2FastSS4U
So what you're saying is that the mount is good but the battery trays are good but only if I use lipo's because of the weight savings? I've seen a savage run a Novak HV4.5 on youtube and it looked impressive, do you think this motor could really push this heavy of a truck? Also I've been seeing these brushless savages with the stock dual disk brake system still working, whats with that, I thought ESC's were able to control braking as well.
Well yes they can. It will put more load on it though (heat). But if you use the stock transmission unless you modify you will need to use the transmission's reverse (if it has it) and brakes. Then people like rckcrwlr who are using a Phoenix which is an airplane controller. So it doesn't have a braking profile that would be very usable for a truck.
