Thread: tuning problem
glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.15.2007, 06:15 PM
Do you have it just at idle for 30 seconds or does it run ok and rev up??
Does it only die when it comes back to idle?
It may be tough to guess what is wrong if it won't run for more than 30 sec... my nitro *cough* takes that long just to warm up and start running ok. Really it takes a couple laps opn the track before it's acting ok.
After it starts, get it revving good... with brief full throttle stabs... keep doing that for a minute to get the temps up and keep it running. If it won't do this then I'm not sure where to start.... other than to go back to factory spec needle positions.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
