Serum
Serum's Avatar
04.16.2007, 02:45 PM
A UBEC replaces the receiver battery. It transforms the higher voltage of the batteries into 5 or 6V.
If you want to use the mechanical brake, you need the Y cable. (the revo uses a Y cable allready, you can use that one) put both the controller and the brake servo on the same channel. (throttle) you need a servo that works into the right direction. Some work in opposite to others.
and yes, the MM controller is programmable to forward only.
